mechanical fateners loads
How do you calculate the shear and tension loads for mechanical fasteners in concrete?
RE: mechanical fateners loads
What kind of fastener?  Wedge type?  Epoxy bonded?  Tension capacity will be different; however, shear is essentially the same.
Please clarify your question.
Check with MFG - most have very good tables.
