Ram Elements / Direct Analysis Method
Is Ram Elements able to implement the Direct Analysis Method similar to Ram Frame? Thanks!
Neffers
RE: Ram Elements / Direct Analysis Method
For an explanation of the differences between RAM SS (Frame) and RAM Elements (Advanse) please refer to thin online topic:
http://communities.bentley.com/Wiki/view.aspx/RAM_Advanse_Importing_From_RAM_SS_FAQ
Regretfully, RAM Elements does not have an easy way to handle stiffness reduction at this time (the user can manually alter the effective inertia of members only). The other aspects of Direct Design (P-Delta analysis, notional loads) are possible.
RAM Elements can handle P-Large Delta (structure effect), but not P-Small Delta (member effect).  I was looking a 4-story moment frame model recently in RAM Element and the P-Large Delta effect made a big difference.
Look for the fact that RAM Elements can handle P-Large Delta effects at the ends of a member. So if you divide your member in segments you will achieve something like the P-Small Delta effect.
carlosvalinhas
That's what I have done before.  However, I wish they had something a little easier to implement.
