F06 Shear Output Calculation
Hello all.
I have a question regarding the f06 load and stress outputs for a CQUAD4 element defined with PSHELL properties, specifically in relation to the following.
I've been trying to determine the calculation of the shear stresses that NASTRAN outputs for a CQUAD4 element. Is it the sum of the quotient between the elemental Nxy outputs and thickness (ie. Nxy/t) and 6Mxy/t^2, for an element under both in-plane and bending loads? Note "xy" are being referred to as subscripts.
Or am I just way off-base violating the basis of the CQUAD4 derivation all together by considering the combination of the two???
Much appreciate enlightenment  on the matter.
Thanks in advance,
Silver
