calc: min thread engagment - where find min/max thread dimensions
Machinery Handbook 27th ed page 1510 provides method for calculating minimum length of thread engagement to "prevent" stripping of male and female threads. (Yes, I realize only the first few threads matter anyway, but I'd like to do the calc anyway, I won't trust it if it's too long).
The calc involves minimum and maximum values for internal/external thread diameters (pitch diameter, minor diameter, major diameter).
Page 1763 gives the basic (nominal) dimensions, but no min/max. I guess that depends on the tolerance selected. Where to go to find this info? I'm looking at 1.25" 7tpi A449 bolt and and A36 tapped female threads. (UNC).
RE: calc: min thread engagment - where find min/max thread dimensions
In the machinery handbook there is an error in the calculation where it comes to calculating the thread engagement. I know this from personal experience. A better reference to use is the one posted here:
http://ww
Thread tolerances (max/min) can be found in your Machinery's on Pg 1747.
desertfox
Bolts are 1 1/8", 7 tpi UNC
To get more holding power, we are going to put in A449 bolts.
On attached spreadsheet using nut factor 2, I calculated torque of 796 ft-lbf to attain 70% of A449 min yield = 0.7*81ksi = 57,700.
Also attached I calculated:
Min engagement to prevent external thread stripping = 0.8".
Min engagement to prevent internal thread stripping 1.27".
I don't remember exactly how much thread engagement we have, but let's say for now I have at least 1.27". Should I feel ok about the female threads?
Does anyone note any blatant errors in this approach or calculation results?
The error was to do with the ratio's of yield stress and engagement lengths of the mating threads, I found it a while back when answering another thread, I'll try and find it later.
Can't see anything wrong with your calculation however you need to know the external load imposed on the fixings by the motor/pump combination.
Also using a torque setting can give about a 30% error in your clamping force, maybe this is why the motor moved, just a thought.
You could check the thread engagement using the reference I posted and see how it compares to the answer from the machinery's.
desertfox
regards
desertfox
Or if you want something free www.boltplanet.com as with anything free on the internet, use at your own risk. Also, don't blindly rely on the calculated values in the stress, I meant more for finding the max & min dimensions.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
http://www.cncexpo.com/AThreadEngagement.aspx
http://www.hexagon.de/dose/form02e.pdf
At the old torque of 400 lb-ft each bolt should provide slip resistance on the order of 4000 lbs +/- thickness of a brick. I'd be suspicious of torque loss due to embedment, etc.
Were lockwashers used?
How thick are the flatwashers between bolt head and motor "foot" ?
Do they show any evidence of "coning?"
How large are the holes in the motor "foot" ?
What kind of location is provided for the "stand" interface downstream of the motor?
If the new fasteners are commercial it would be fun to torque a few to yield or infinity and beyond.
Any way to convert to through bolts and nuts, or do you have a blind hole situation? Longer bolt grip length (MIL specs suggest at least 7 bolt diameters )
Another sidetrack we got to thinking about was the role of shims. We had shims under 2 of 4 bolts. That would seem to dramatically change the friction picture since contact area is dramatically different. But contact area doesn't show up in the simple friction formula Ffriction = mu * Fnormal. I'm still trying to reconcile the math (contact area doesn't make any difference) with my intuition (full contact should be much better than partial contact).
Don't ask me what the as-found alignment was... that information was not gathered due to circumstances to convoluted to explain. We have several reasons to believe the machine has moved and I'm interested if you agree it is plausible based on excel calculations attached.
Nope, never heard of that for mtoro holddown boltsw.
We don't use washers. But I believe there are no anomalies llike this other that we were using a very low torque for thsi size bolt (470).
As far as I've been taught/read friction force is pretty much independant of area, as counter intuitive as this may seem.
Looking at your last calculation I think your conclusion about the motor moving is valid but I'll study it a bit further after work.
Friction is normally considered independant of contact area however where high pressure between to surfaces is encountered friction is no longer independant of area, i haven't got my books to hand at present but I'll expand on that further later.
Having bolts with increased material between the bolt head and inner nut face alters the stiffness of the bolt and joint ie a longer bolt of the same diameter under the same load will stretch more than a shorter one.
regards
desertfox
-- MechEng2005
Studied your calculations further now - and again your reasoning appears logical. However, there is one factor that has just occurred to me and that is, in one of your later posts, you stated that the motor had been leaking oil for the last two years. This seems to be an awful long time for the motor to slip out of line on the basis of reduced friction between mating faces.
Also, for the motor to move, this means that either none of the bolts are in contact with the bolt holes or only one bolt is in contact with the bolt hole to act as a hinge. So the amount of movement the motor could possibly make is only that clearance between the bolt and the bolt hole.
You are saying the motor has gone out of line, what problem has this caused? I would have thought the rigid coupling would have prevented the motor moving too far.
desertfox
Questions:
How much movement is needed for misalignment?
Is the pump supported independently of the motor?
Is the stand braced with bracing members and rigid connections to keep its shape or could it have warped?
Has the motor been checked to see if it is an internal problem?
Timing has a lot to do with the outcome of a rain dance.
