120v prox input to plc
I am using a 3 wire 120vac prox switch as an input to a micrologix plc. The input is dropping out(indicating light flashes off then back on erratically). If I wire the prox directly into the plc bypassing all the field wiring the input responds the same way.
Is a resistor the answer?
RE: 120v prox input to plc
Russell White, P.E.
Automation Technologies, Inc.
www.AutomationNC.com
Automation Help
www.PLCMentor.com
I added a 1/2 second off delay timer in the program. That has stopped the input from causing chaos but I would still like to know what the issue is.
Keith Cress
Post your Prox switch part No and your PLC input card. so we can recommend a solution.
Roy
AB Micrologix1500 1764-24AWA
neutral -Blue(prox)-ACcom0(PLC)
120vac -Brown(prox)
Black(prox)-I/1(PLC)
Russell White, P.E.
Automation Help
www.PLCMentor.com
