Chapter K Specs
Chapter K Specs
The Bp coeffiecient is what measurement of the plate? Is it along the connection or perpendicular out from the column? Also if a single plate shear tab connection is used, do the bolts connecting the framing member have a reduction in strength due to the local bending moment?
RE: Chapter K Specs
Mike McCann
MMC Engineering
RE: Chapter K Specs
RE: Chapter K Specs
Mike McCann
MMC Engineering
RE: Chapter K Specs
RE: Chapter K Specs
