leakage inductance and coil PCB with Altium design
hello everybody,I have two problems with Protel altium design 2006.
- the first is that, I would like to know if there is a tool to have a leakage inductance creates by a track after routing (my PCB is made in FR4).
- the Second is to know if there is a tool to create coils on PCB (example: an antenna RFID on printed circuit)
thanks for your answer
RE: leakage inductance and coil PCB with Altium design
Item #1 is best done with an FEA/EM package after you've designed it.
Item #2 is best done with a graphics or CAD package like Illustrator, Corel, AutoCAD, etc. and import... at least with the 2006-era package.  I believe the later packages are better suited to creation of such items.
Dan - Owner
http://www.Hi-TecDesigns.com
