can't open or run NX6
Dear folks,
when i try to run NX6 after installed this error comes
why? anyone answer me?
"ugraf.exe – Entry Point not point
?Jam_ask_active@@YA_NABV?$basic_string@DU?Char_traits@D@std@@V?$SMALLoc@D@Memory@UGS@@@Zcould not be located in the dynamic link Library libjam.dll"
Thank you in advance^^
RE: can't open or run NX6
Many things can cause this error, did you install latest QRM and MPs?
may be you can try re-installing the whole package. Let us know how the problem was solved after you find the solution.
Ram
