Simulate 3-point bending of tube?
If I wanted to do a 3-point bend test for a tube in Solidworks using COSMOSWorks, how would I go about it?
I'm using Solidworks Office Premium 2008 (64bit edition).
Thanks!
Thanks!
RE: Simulate 3-point bending of tube?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
Solidworks just doesn't seem to want to behave when it comes to working with a tube.
The test is on a thinwall tube (1 meter long, 1" O.D with a .049" wall thickness).
Can you post screendumps of your model?
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Simply supported at one end.
Simply supported slider at the other end.
Load the center node. (you did arrange for that?)
TOP
CSWP, BSSE
The only real FEA I've done with solidworks is tensile tests.
To get the boundary conditions stated you would take your model which would be based on two equal length collinear curves and at one end you would fix UX, UY, UZ RY and RX. At the other end you would fix UY and UZ. In the center you would apply -FY.
These boundary conditions would not work on a shell or solid model without additional construction.
TOP
CSWP, BSSE
Can I have non-member reference points?
TOP
CSWP, BSSE
