APLUS Internal programing error
When starting Ideas, a few of the users will get this error after selecting their project and model, or even if they start a new model. The exact error is "APLUS Internal programming error 15101 in routine MSGONL" they will also have a box pop up with a Ul in it but there are two dots above the U.
When I log into the computer with an administrator acount this error doesnt occur, but when any user tries it does this. Also it creates a locked file of the model you are trying to open. In this case we remove the locked file and then it produces the error above.
I checked permisions on all the files that it might need, but I couldn't find any problems.
I tried reinstalling, but this didn't help either. I think it may have somthing to do with the Team directory, but I have no idea.
Thanks in advanced. The systems are 32 bit xp and we are running IDEAS version 12. The licenses are served off of a license server.
RE: APLUS Internal programing error
I just got off the phone with GTAC and he suggested I delet the user_param files in the team master file. I am now waiting for the user to come back from lunch, so I can see if that works.
Let me know if you have any suggestions.
You do this by going to start
run
type "regedit"
Then navigate to the registery HKLM/software/SDRC/UUID/1.0
right click and select permissions.
Set users to habe full control.
then click apply
Thanks for the help though.
