Transformer Secondary Conductor Sizing
Hi all,
I am aware that NEC requires 125% over-rating factor maintained on top of cable deration. I have a transformer with a secondary full load current. I'm sizing it to be equal to 125%FLA/de-rating factors...then select the cable size.
However, if these cables are connected to a switchgear...is the 125% rule still valid if the switchgear busbars are rated for 100% current rating? If the Code says transformer secondary conductors...does it mean that the switchgear bus bar is also included?
RE: Transformer Secondary Conductor Sizing
Alan
"It's always fun to do the impossible." - Walt Disney
Rafiq Bulsara
http://www.srengineersct.com
See Rules:
14-100
(b)
(c) if the bus feeds a single overcurrent device.
Bill
"Why not the best?"
Jimmy Carter
I have a 13.8-0.48kV, Delta-Wye (solidly grounded) 1.5MVA power transformer feeding a downstream 480V switchgear.
The secondary full load is 1804.22A. Assuming no deration, the calculated required ampacity will be 1.25 x 1804.22 = 2255.30A. In CEC Table 2, using a 90 Deg C conductor, 750MCM at 5 conductors/phase will suffice = 500A x 5 = 2500A. This is to comply with Code.
However, with this FLA, can 2000A busbar rating be specified on the 480V switchgear (since the busbar is 100% current rated)?
What if I'll use 4 x 750MCM conductors = 4 x 500A = 2000A and ensure that the overcurrent device is set to pickup at 2000A, can I deviate from the code?
Based on what requirement?
Bill
"Why not the best?"
Jimmy Carter
"Throughout space there is energy. Is this energy static or kinetic! If static our hopes are in vain; if kinetic — and this we know it is, for certain — then it is a mere question of time when men will succeed in attaching their machinery to the very wheelwork of nature". – Nikola Tesla
"Is the bus considered part of a connected device or an extension of the conductor."
Bill
"Why not the best?"
Jimmy Carter
There is nothing wrong with having a standard 2000 A breaker on a 2000 A bus. It does not have to be 100% rated, and almost never is. It just means that the sum of the non-continuous and 125% of the continuous load cannot exceed 2000 A.
In Canada, I have no idea.
There is primary circuit breaker and a secondary circuit breaker. However, the secondary cirucit breaker is in the switchgear interconnected by cables.
My question, dealt more with the fact that if the cables have a 125% factor, does it necessarily mean that the switchgear bus bars have the same 125% factor with respect to continuous load.
I am looking on a scenario where the equivalent ampacity is based on a 125% factor and the bus bars on a 100% rated factor.
Overcurrent devises above 100 amperes are Listed for use with 75 degree C cable Ampacity.
NEC 110.14(1) (b)
At least for UL listed breakers.
Here's the link
http
