ASME TDP-1 and level sensing device for a drain pot
Dear All,
Can anyone inform me on available level sensing devices in the market, acceptable to TDP-1 that can be used on drain pots at high temperature&pressure applications .
I understand float type level switches may not work for 1800 psig, 1050 deg F high pressure steam for example. Is this true? Per internet search there are conductivity probes marketed under the name TWIP system.
I am wondering what else is available.
Thanks for any help
Thanks for any help
