solidworks Volume calc
Does any one know is solidworks has the capability to calculate the volume of an part or assembly?
thanks
thanks
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: solidworks Volume calc
Save the PCB and frame as a part.
Create a solid body (not merged) around that part.
Use the Combine function to remove the PCB/frame part.
Or you might be able to use the Cavity function in a new assy.
