what is the difference between pressure relief valve and safety valve?
please elaborate on the subject. i am working as a maintenance engineer in FACT,india.
what is the difference between pressure relief valve and safety valve?what is the difference between pressure relief valve and safety valve?(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: what is the difference between pressure relief valve and safety valve?
For example, a thermal relief valveis used to bleed off pressure in a heat exchanger if the heat exchanger is isolated but the possibility of thermal expansion of the fluid could cause over pressure conditions. The capacity of thermal reliefs are generally small.
A safey valve on a boiler or other types of fired pressure vessels must be capable of removing more energy that is possible to be put into the vessel. 110 percent of boiler rated capacity may be acceptable. The ASME Boiler & Pressure Vessel Code would be the source to check for adaquatley sizing safety valves.
A safety valve is an automatic pop type valve used primarily in steam service.
A safety relief valve can be used in either service, provided necessary adjustments are made to have the valve perform correctly (proportional or pop full open)dependant on the service conditions.
A safety relief valve has (2) positions closed & full-open. The valve nozzle/disc assembly contains a "huddling" chamber to assure this snap-action upon opening.
J. Alton Cox
President
DeLuca Test Equipment
www.delucatest.com
Relief Valves are also automatic pressure relieving devices but they are characterised by proportional opening, depending on pressure above set pressure. They are used for incompressible fluid service eg. water.
Steve
In a Safety Valve (SV)on Steam, Air or Gas, the Lift is typically 60 to 70% of Full Lift at initial opening. Further lift is gradual up to the maximum overpressure.
In a Safety-Relief Valve (SRV), the Valve will act like a Relief Valve on Liquid or a Safety Valve on Steam/Air/Gas.
One of the problems with using the terms interchangeably is the DIfference in Adjustment Ring Settings. Failure to recognize the differences between RV, SV & SRV is what separates a Mantenance Mechanic from a PRV Technician.
J. Alton Cox
President
www.delucatest.com
