no surfaces or faces showing
Got a problem. Working on a, somewhat, large job and now the only thing that shows is solids and text. No faces and surfaces are seen. They're not in 'no show' they just aren't coming up, yet if I bring the job up on another computer everything comes up fine.
I'm not sure if there's something wrong with the software or if I have accidentally set something to do this.
BTW. If I work in cache mode (visualization) I can see the faces and surfaces fine. Yet, if I go into design mode they disappear. Not from the tree, just from the screen.
Would appreciate any help.
Thanks, Sean
RE: no surfaces or faces showing
Check Tools, Options, Infrastructure, CGR Management and see if "Save Lineaic Elements in CGR" to see if it is set the same on both workstations.
Check that only currennt body isn't on. Make the part body to current and see what happens
Also, check Tools/Visualization Filters and be sure that all visible is selected
