BS 970 817-M40 T Hardness
Please does somebody know the hardness value (vickers)of the base material BS 970 817-M40 T?
Many thanks
gioi
RE: BS 970 817-M40 T Hardness
The steel in question is 817M40 (the old EN24) and classified as through hardening.
"T" is the hardened and tepmered condition, and in this case "T" is 55/65 ton/in2.  The quoted hardness in this condition is 248/302 HB.
FYI, 248-320 HB is equivalent to ~ 260-320 HV according to ISO 18265 Metallic materials — Conversion of hardness values.
I have found values in hte range of 260 - 300 HV but after mechanical treatment (deep grinding). The normal value (before to remove material) was around 400 HV!
