Slab Design
Slab Design
Slab Design
I am currently designing a 11 storey residential apartment building. I have a 2 way rc "end span" slab restrained on all 4 edges with 400x 600dp beams. Beams are spaced at grids of 7.8m & 8.1m. Data as follows:
LL = 2 kPa
SDL = 3.0 kPa (inclusive of 150 series NLB blockwalls)
DL = Slab self weight
fc' = 40 mPa concrete
fsy = 500 mPa steel
RE: Slab Design
So what you want to know.What is your question?
RE: Slab Design
sorry got disturbed by the graduate engineer :) Slab thickness & rebar please.
RE: Slab Design
it needs more details than that and the employment of an engineer.
RE: Slab Design
thickness 350mm
24mm bars at 150mm centres each way top and bottom.
RE: Slab Design
Tomfh are you pulling his leg? ponder
Arguing with an engineer is like wrestling with a pig in mud. After a while you realize that them like it
