Reverse engineering for m/c head design
I've got a Suzuki GS500 motorcycle, air cooled 2 cylinder DOHC shim on buckets operating 2 valves/cylinder.  Not very high performance, but market longevity attests to it's design durability.  I believe Suzuki originally produced a contemporary 1000 cc model with 4 valve head, but the 500 got 2 valves in keeping with its more utilitarian application.  I wonder why they may not have chosen a single cam design at presumably lower parts count/cost?
RE: Reverse engineering for m/c head design
Compare parts count:
DOHC: 2 camshafts, 2 cam sprockets, 4 buckets, 4 shims.
SOHC: 1 camshaft, 1 cam sprocket, 4 rocker arms, 4 rocker shafts, 4 screw/locknuts.
Not a whole lot different at the end of the day.
If they already had the DOHC cam drive designed then design reuse saves making & testing new parts.  Also, don't forget DOHC was probably a strong marketing buzz word back then.
Wasn't the GS1000 a DOHC 4-cylinder with 2 valves/cylinder?
- Steve
Suzuki built many engines both SOHC and DOHC. The GS1000 that I am thinking about, which was 1980-ish, was Suzuki's first (I think) production engine with DOHC and 4 valves per cylinder, and so-called TSCC (Twin Swirl Combustion Chamber).
Looking back from today, that bike seems like a lump, but it was as state-of-the-art in its day as the GSXR1000 was 20 years later.
Thanks for the ideas folks- The design reuse explanation has an ironic appeal, because the daughter application has lasted 20 years- much longer than the parent!  Sort of a case of the tail wagging the dog. . .
