Hydronic heating component ASME BPVC requirements
Do hydronic heating components (piping, manifolds, etc.) fall under the ASME Boiler and Pressure Vessel Code (if adoptet by certain jurisdictions)? E.g. would a manifold block, that is used to connect a boiler to several heating circuits, be considered a pressure vessel and need an ASME certification? The maximum operating conditions for the heating water would be 230deg F and 87 psi.
RE: Hydronic heating component ASME BPVC requirements
Per ASME you do not need any certification or stamping.
