Ti Weld Repair
Ti Weld Repair
Hi everyone, perhaps somebody may be of assistance, I was inspecting a Ti weld Ti 6 AL 4V, I´m concern due that after repair it was cracked within the weld, it was repair and after another inspection it continues to crack and so on..I´m aware that some codes or spec. does not allow to repair more than 2 times, However I haven´t found any spec at the moment to support how many times it could be repaired, I´m really sure the welding procedure is incorrect. I´m not quite familiar with Ti welding therefore can someone please suggest me or inform where can I get information about this type of welds (spec) or if metallurgical speaking, if there is any risk of more severe damage after many repairs..will appreciate your assistance.
RE: Ti Weld Repair
http://www.timet.com/pdfs/ti-handbook.pdf
RE: Ti Weld Repair
With Ti if you get too much oxygen or hydrogen (air, humidity) the welds will be very brittle. Have they checked weld hardness? I'll bet that it is too high.
They should have ground out a lot of metal before the repair. You grind and then perform NDT to show that you removed the entire crack before re-welding.
Plymouth Tube
RE: Ti Weld Repair
RE: Ti Weld Repair
I agree with Edstainless, they should have documented that a certifiable repair was possible before trying it on the work piece.
