Compressibility factor for water
Dear All,
I need the value of compressibility factor for water with restricted pressure 1000 psig or below.
Thanks for any valuable replay
RE: Compressibility factor for water
According to a number of references that I had to find for a project recently, the volumetric contraction of water is 0.2% per 1,000 psi.  So if you have 1,000 gallons of daerated water at atmospheric pressure, you would have to add 2 gallons of water to reach 1,000 psia or 4 gallons to reach 2,000 psia, etc.
Drexl's number from wiki is 0.36%/1000psi.  I found similar numbers to that for hydraulic oil, but the most common number I found for water was around 0.2%/1000 psi.  For the project I was working on, that would have mattered.  For pressures under 1,000 psig I don't think the difference matters.
David
For liquids its more conventional to talk about their Bulk modulii, which for water (at STP) is 312,000 psi.
The bulk modulus K can be formally defined by the equation:
K = -V ∂P/∂V
where P is pressure, V is volume, and ∂P/∂V denotes the partial derivative of pressure with respect to volume. Compressibility of water is 1/K = 0.003205 in2/lb
or in this case 3.205/1000 psi, getting pretty close to zdas' value.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
Thank's all for some precious feedback.
