Document Recovery Issues
Hi All,
I've been having a consistent issue with my 2009. Any time it crashes and I go to choose document recovery the list below is blank.
However if I select open all it will open up my autorecover files for me. And on top of this when I try to save the autorecover version it tells me it has failed to save the document.
Anybody run into this?
SW 2009
SP 3
Vista 64
Geforec 8800 XT
60% of the time, it works every time.
RE: Document Recovery Issues
I would imagine that it has something to do with how SW is terminating with the error.  Maybe a trigger isn't being sent to the auto-recovery to activate it.  I'm running 2008 and it happens with that version as well.
So far, autorecover only works like I think it should when I set up a test case to demonstrate how nonfunctional it is.
On real files, its track record is disappointing in extremis.
Mike Halloran
Pembroke Pines, FL, USA
Wow bit of a hot topic.
I'm concerned about issues working with Photoworks when you're doing lots of material editing and then it crashes and all your precise slider work is lost. Even losing 2 minutes of slider adjustment is a pain in the but.
However I didn't know that there was a performance gain by disabling it. Looks like I'll be a Ctrl+S fiend from now on.
Cheers
I have all of that stuff disabled and live with crashes, it seems to work for me. If you get the failed to save document error, just save it under a new name and rename through windows.
