Generator Hydrogen Coolers
We have a hydrogen cooler for a large electric generator, which requires 2000 GPM of cooling water at 85F. I know the heat load. Evaluating cooler performance with new coolant properties an new coolant temperatures, I need to know the Hydrogen inlet/outlet temperatures.
Does anyone know the typical Hydrogen temperatures for large (300 - 1000 Megawatt) pressurized hydrogen cooled machines. Have the temperatures become fairly standardized over the years (like so many parameters for well evolved machines) or are they all over the place.
I am not able to find this data on this 450 MVA machine manufactured in Japan.
Thanks in advance for any help
RE: Generator Hydrogen Coolers
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
The cooling water flow is 4000gpm and the temperature 95F.
However the final hydrogen temperatures will depend also on the hydrogen flow and the cooler transfer area.
