PDMWorks - Select active document in vault tree
Running 2009SP2.0
A simple request I think. Is it possible to select the active document in the vault tree? Sometimes it seems to automatically do this, other times not. It would be especially useful when working on drawings, as there does not seem to be a "reload" or "get write access" command in the menu
It seems crazy to have to do a search in the vault for the document you have open in front of you, but I find myself regularly doing this
I started down the route of creating a macro to get write access to current document, but got a bit lost. It seems you have to log in to the vault through the macro, so I would not be able to roll this out to all users. However, if there was a command to just select the active document rather than take ownership, I could set up a dummy user in PDM and it would not matter, as the take ownership command would be carried out by the user.
Any ideas / workarounds?
RE: PDMWorks - Select active document in vault tree
Try going to Solidworks WOrkgroup PDM Options.
Then "Vault" tab.
Check the "Show selections In ProjectManager" box.
I think this does what you are looking for. If I check it, and then click on a part or assebembly in my Solidworks feature tree, it will then be highlighted in the PDM Vault tree.
Aaron
SolidWorks (x64)/PDMWorks 09 3.0
CADKey 99 R1.0 (Yes, still using it!)
Of course, hearing that PDMWorks is not doing something correctly is not surprising...
Aaron
