What grade of steel is used in fire tube boilers?
I'm just curious. I know a colleague who has a kiln that operates at 2200 deg F. He uses carbon steel carts on tracks to load and unload the kiln (the carts stay in the kiln during firing). He rebuilds carts non-stop because of heat damage. There's got to be a better grade of steel he can use.
RE: What grade of steel is used in fire tube boilers?
