losses by using a Zig-zag transformer
We are providing power to 25KV line through Step up transformer (4.16kv/25kv). The utility specified Delta(25Kv) Wye(4.16KV), and later on they asked us to add Zig-zag transformer to avoid the potential over voltage issues. We were asked to assess the losses as a result of using Delta-Wye+ zig-zag transformer.
one loss I can think of is, the failure of the additional equipment-Zig-zag trnasformer would cause some loss over the years.
Are there any loss difference between Delta-wye+ Zig-zag and Wye-wye?
Any inputs would be appreciated.
RE: losses by using a Zig-zag transformer
The utility wants to know a comparison of Watt losses between the two options.
What I guess is there will not be much difference in terms of watt losses between the two options. Additional loss in Zigzag trafo (only no-load loss need to be considered during normal operation) will be compensated by the less copper losses in Delta/Wye trafo (when compared to Wye/Wye trafo).
For numbers, a manufacturer will be in a better position to advise.
Bill
"Why not the best?"
Jimmy Carter
