From "lean Manufacturing" to "lean Engineering"?
Dears,
I am a process engineer working in an engineering company.
Recently, i have been proposed to participate to a conference on "lean manufacturing" and "lean engineering" with people from various fields (automotive, aeronautics, ...) but i am not familiar at all with these concepts.
I have made some research on the net. I have found a lot of info. but i hardly succeed in relating the "lean" concepts to my day to day activities.
What i understand is that "lean" aims at maximizing the production of valuable product by minimizing the so-called "wastes". But this seems very vague to me.
Then, i would like to know if you have experienced these concepts as chemical engineers (in an engineering or manufacturing company) and if you would accept to share your views on it. Any ideas/references will be more than welcomed.
To put it in a nutshell: What?, Which?, When?, Why?, Who? and How?
"We don't believe things because they are true, things are true because we believe them."
RE: From "lean Manufacturing" to "lean Engineering"?
It's managment speak for things like kanban, kaizen, Just In Time and the like.
Don't get me wrong, there can be little gems hidden in all the consultant BS but basically it is about minimizing waste/maximizing efficiency.
For example, where I currently work by 'lean' they basically mean that rather than building a sub-assy and then booking it into stores you instead buid a sub-assy then put it on/in the relevant production line shelf/bin for use in the next stage of the pseudo assembly line.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Mike
NomLaser, obviously, the path to lean engineering involves knowing just exactly what is to be designed and how, exactly what problems are to be solved and how, before ever starting so that all that wasteful iterative effort is avoided ;)
Is it Monday yet? Yeah.
Mike
Mike
Most of what we call management consists of making it difficult for people to get their work done. - Peter Drucker
corus
Have never heard of Lean engineering. But I am sure I have experienced it ;) I agree with a lot of the others. It could even just involve designing more modular components, wearing multiple hats etc.
In the end it is bad for everyone. I would rather my company be able to design a different junction box for every vehicle line just to keep more workers employed both in engineering and manufacturing. But those days are long gone.
As with most things in life a compromise usually offers the best solution. But that does not mean that companies should not strive to be more efficient or people in smart suits should not "earn" loads of money for chucking buzz words around.
it's easy to figure out the cost of bad engineering, it's very hard to put a value on good engineering ... an "optimum" structure doesn't tolerant off-design conditions well and doesn't allow for future growth (increasing load capacity). a robust design does these things.
and what is efficient engineering ? trying to make the best product for the least cost. so, we try to get ahead of the curve, see what materila we've got available, talk to the "plant life" about how they'd want to make something (bent up or machined), go down that path only to change Everything 'cause the manu. mgr wants to offload to a water jet fabricator ... sigh. is it efficient to make a weight efficient structure that costs a bunch to make ? (clearly) no, so where the thing's being manufactured factors into the design decisions, and that can change at the drop of a hat.
is it Friday yet ?
One aspect I would consider "lean engineering" would be to make parts symetrical so that they can be used in multiple places. In some cases where I'm at, we had "left-hand" and "right-hand" versions of the same part. They were easy enough to tweak to make them the same. Makes life a little easier if you are stocking one part instead of two, don't need to try to differentiate at assembly, etc.
Another aspect might be bolt sizes. I've seen many engineers go through a design and size the bolts appropriately. However, in some cases they specify an assembly to require (28) 1/2" X 3" Bolts and (14) 5/8" X 3 1/4" Bolts. To me, if the larger bolts will work all the way around, it's better to just use (42) 5/8" x 3 1/4" bolts. Less bins to pull hardware from, easier to find the right pieces at assembly, easier for drafting (all holes same size), easier to manufacture, etc...
However, I'm not sure these are the concepts meant by others when they say "lean engineering." In fact, many places may tend towards trying to use the smallest and cheapest bolts and such to minimize cost. Of course, then they wonder why it's taking 10% longer to assemble or complain about some field assembler that mixed up bolts that differ by 1/4" length and have to go back and remove bolts that were already installed.
Obviously, some companies/people are more careful, more organized, etc that can make the issues about grabbing hardware from different bins, getting the right items at assembly, etc less of an issue. However, I still wonder if the little bit of extra time and thought it takes is justified by the $0.02 savings per screw.
Sorry for the rant...
-- MechEng2005
If you do things right the first time, and have enough time to properly test and prototype then you truly are "lean" on most respects. Since most companies can't even give that time.
James Spisich
Design Engineer, CSWP
Minimize spares or use two 75% units versus 2 100% units.
beaware of the cost benefit ratios as you do the design. Will a .2% under design that saves millions be worth the added cost.
Well if you produce 100,000 vehicles a year with a five year run and 100 screws in every vehicle saving $0.02 per screw gives a total saving of $1,000,000 that has got to be worth a little bit extra of anyone's time. If you can reduce the part cost of every component in the vehicle the savings are simply huge.
An example is alloy wheels. The tools are expensive and bulky. So wouldn't it be a great cost saving to use the same wheels on two different cars?
No.
The tools have to be completely refurbished, which takes 6 weeks, after so many cycles (of the order of 10000 wheels, ie 2-3000 cars, or say one or two weeks production), so if you are making twice as many of one design, you need twice as many tools.
In fact the main cost of an alloy wheel is the metal (by a huge margin), so if you can design a lighter wheel for the lighter vehicle, it might even be cheaper, in addition to whatever marketing advantage you get from unique wheel designs. Of course there is extra up-front validation work required on two wheels instead of one, and there is a stocking cost in the assembly plant.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
- Steve
sometimes its "permies good, contractors bad" ... permies are perceived to have more interest in the company, will make better long term decisions, not just interested in how many hours they can scribble down on their timesheet this week, nor would they jump ship at the drop of a hat for an extra $1/hr.
other times it's the opposite ... contractors are a skilled flexible workforce that can be tuned to the work load, permies are inexperienced (and thus too brave or not brave enough), too slow to react to changes, unwilling to reach outside the box.
To me, the concept of "lean engineering" would be to understand the whole process from first concept to shipping it out the door and warranty issues, and basing the design on what works best throughout the process.
Personally, I feel that "lean engineering" is just some jargon for what has been expected of engineers/designers for a long time. Just some new buzz words to "repackage" an idea that's been around forever to sell it to management.
-- MechEng2005
What gets me about my current place is they seem to want to apply principles based on production rates/quantities similar to mainstream automotive when our actual run rate is more like Morgan or Ferrari.
Sure, we could spend hours fine tuning these things, $1000's on tooling fixtures, man weeks spent creating step by step assy procedure etc. but when we only build maybe 5 a month of any particular product, with maybe a product life of 5 years are we really recouping our investment? Or would we be better off having slightly more highly skilled shop floor staff that can work without these aids, freeing engineering up to design the next new product and beat our competitors to the market? Of course, given the way we (don't) track engineering time and amortize tooling costs etc. we may never know.
My office is currently attempting to practice lean engineering as it lays off more and more engineers. Of course, the engineering work load has dropped as projects fail to materialize. Sometimes it seems like it is simply a matter of time before the value of lean engineering approaches either infinity or an indeterminate state.
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
It's my experience the processes owned by the politically weak targets are the ones leaned. Politically unassailable divisions that cannot be looked at with a critical eye are spared the exercise.
We had a politically strong group conducting exercises to lean error correcting processes. At the same time, we couldn't get resources to develop tools to support core functions to keep us from making the errors to begin with.
I do support improvement, sometimes the packaging and motivational stuff gets to be a bit much.
Make it look good whatever you do.
