2" -0.003/-0.007 allowed in asme y14.5?
I had a badly fabricated pin where on the drawing it was indicated 2" -.003/-0.007 and they machined it at 2" exactly (+/-0.0005). I've been in the code asme y14.5 1994 but it is not clear.
Code just claim we can put fit tolerance (where we have -/-) for metric fit. Other examples are just with (+/-)
On the drawing it was the stacked version but still with 2 minus signs.
Do you think it can be misleading as a quote or it is obvious for whomever should be working with drawing?
RE: 2" -0.003/-0.007 allowed in asme y14.5?
Y14.5M-1982 shows some examples of +0/-X unilateral tolerances and +X/-X or +/-X Bilateral tolerances.  The text itself states:
They also have a recommended metric tolerancing setup:
_______________
29.980
29.959  (30 f7)
____________________
30 f7 (29.980)
      (29.959)
30 f7
James Spisich
Design Engineer, CSWP
Sorry I cut off the text halfway through writing it after just copying the examples for the fit tolerances.  Forgive them not lining up.  Doesn't work so well in a little text box.
James Spisich
ANSI Y14.5M-1982 Section 2.2.1.1
It has a figure with the above example as a recommendation when a system is introduced by an organization.
James Spisich
My opinion though is it should be changed to a base number +x/-x or +0/-x just as easily as what they left it, without the confusion of having double negative tolerancing.
I've seen it before, but I don't like it for the reason you're posting.
James Spisich
For people who've worked metric limits & fits or other systems where similar is used it's not really a problem.
For people that haven't worked in such systems though it can be confusing, they may assume the upper value should be +ive.  Of course, if not sure they should ask whoever they got the drawing from and so on back to the designer/custodian, but that doesn't always happen.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Like the example though, usually you'd have a nominal dimension calling out the metric fit tolerance right next to it.  That's the way I've always seen it personally.
James Spisich
While I have seen it used, I have also seen parts made under the incorrect assumption that the tolerance was ± almost as often.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Not sure about usually, at least your usual may not match mine.
I think I've seen it with rivet holes, the hole size is given as the nominal rivit dia.  The tolerances are then +/+ these weren't to any metric shaft fit basis or whatever.  They were in good old fashioned inch, based on the tolerance in the rivit spec.
