Stacking sequence & moment of inertia
Quick question fairly simple for most of you but I am confused.
In the following sentences, please assume that E is the Young Modulus (MPa), I the second moment of inertia (mm4), t the thickness in mm and h the distance of the ply from the neutral axis.
To determine the EI value of a laminate, that allows one to improve the stacking sequence, one obvioulsy needs to know the E value( which I am happy to determine) but also the I value.
I know that it can be assumed as the sum of the ((Ei^3/12)+(tihi)2.
Which makes it very easy to find. But I am actually making a spreadsheet, that I will post if some of you need once finished and checked, and I can't find the relative height of a ply from the neutral axis. At least I can't make the process automatic as
Do you see my problem? Basically the NA is at half the laminate thickness but the height depends on the n° of ply and the thickness of the ply.
Is there a mean to find the I from a baseline (say the inner ply) and then convert it as a usual I from a neutral axis?
I hope I have been clear enough for you to help me.
Thanks a lot by advance. Vincent
RE: Stacking sequence & moment of inertia
To find the neutral axis of a set of layers:
Assuming a strip of one units width:
Sum(E*thk*1*thk)/Sum(E*thk*1)
In the attached spreadsheet you can find an example.
Onda
Onda, thanks a lot. Vincent
