Multiline parameters for region repeatition tables
Hello Everybody,
we have been using Pro/E WF2 for 1 year and we'd like to know how to add a parameter with multi-line text to be included in a table with region repetition feature. Let me explain with more accuracy:
_ let's say we have a .prt named JB.prt
_ we put this .prt file in an assembly with a table and BOM balloons
_ we'd like to create a table as follows:
Item | Name | Description
1 | JB | Junction Box
| | Manufacturer: XX
2 | Body | ....
And so on.
It would be nice to create a string parameter called "Description" to be put in the table with a pointer (for example &asm.mbr.DESCRIPTION) for our auto-filling table.
The problem I found is that the parameter can be only a string with a single line and not a multi-line text.
Is there anything that could satisfy our request?
Thanks a lot for your help
Bye
F2004
| | Manufacturer: XX
2 | Body | ....
And so on.
Bye
F2004
RE: Multiline parameters for region repeatition tables
To be able to do that, you will need to highlight the cell, right-click & select Properties. You will then be able to add the second parameter on a new line.
Fighter Pilot
Manufacturing Engineer
