Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have found your site brilliant. What makes it good are the people that contribute to the site..."
Geography
rittz (Structural)
13 Sep 09 21:52
How does one calculate the depth and diameter of laterally loaded cast-in-place concrete piles.  Planning a conc pile cap on 2 or more piles to carry the structural steel base of WF vertical columns forming a closed sign 12' wide and 25' high. Not fussy about embedding the WF columns. Obviously it's going to be a function of certain properties of the soil. We are confident of the appropriate wind load we have researched.
asixth (Structural)
14 Sep 09 6:42
I did a large sign like you have described not so long ago (45' x 8') which had two 4' diameter piles embedded 14' into the ground. The best thing to do would be to speak with a geotechnical engineer (has a geotechnical engineer been engaged for the job) and ask them how much passive resistance the soil is capable of. I had a geotech recently give me advice that the passive resistance that the soil can tolerate is 9*Cu where Cu is the undrained shear strength of the soil.
I am unsure on what the soil material was (I will dig up the design tomorrow at work) but you can back-calculate what soil strength you need to resist the overturning moment and give this to the geotech and see what they recommend.
Personally, I don't think a pile cap will be necessary. You could just have the WF columns bear on the pile head (with a thick size baseplate, typically 1-1/2"). I would also embed a end-plate welded to the hold-down bolts.
I can attach a sketch if it were to be more helpful.
Look at some standard drawings for highway sign structures from your local DOT, they should be a good indication on what the design looks like.
rittz (Structural)
14 Sep 09 9:20
Thank you kindly ASIXTH.  Yes It would be helpful if you could send a sketch and I appreciate your offer. Can you do that here? We will be working in medium to low plastic clay
Close Box
Join Eng-Tips® Today!
Join Us             Close
