Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks for a great forum. My problem was answered just by scrolling through previously solved problems. Great service!!..."
Geography
Ostoich (Aerospace)
13 Sep 09 18:09
I am having trouble meshing a geometry that is composed of several solids.  Each solid is triparametric so they are easy to mesh with isomesh.  However, I am having some problems.  First, in some of the solids, the nodes are matching at the edges of abutting solids, but not the surfaces.  Some of the solids have very distorted meshes inside of them, such as in the attached picture.  Does anybody know the solution to this?  Is there any way that I can constrain the mesh lines to constant x or z planes?
-Ostoich
gwolf2 (Aerospace)
27 Sep 09 6:42
I have seen this very occasionally. In this case I rebuild the solid from surfaces and re-mesh. If the problem remains it is because one of the surfaces is a bit wierd in which case I refit the surfaces and try again. Useful commands are:
Edit solid disassemble
Create solid faces
edit surface refit
gwolf
Close Box
Join Eng-Tips® Today!
Join Us             Close
