Neutrals?
Neutrals?
Neutrals?
Can someone explain the difference between closed transition  and over lapping Neutral regarding transfer sdwitches.
RE: Neutrals?
Closed transition - Switch for source 2 closes before switch for source 1 opens. Sources are momentarily paralleled during transition.
Overlapping neutral - Closed transition operation for neutral switch (applies to 4-pole switching only).
Alan
"It's always fun to do the impossible." - Walt Disney
RE: Neutrals?
To add to what alehman said, a 4 pole, open transition switch will/can  also have an overlapping neutral switching so as not to leave system neutral disconnected (and hence maintain grounding too) at any time.
Rafiq Bulsara
http://www.srengineersct.com
