Floating ball valves leaking at low pressure
I'm trouble shooting an instesting problum. Numerious 3" 300# ball valves (floating design) hold fine at high pressure (600 psi) but leak at low pressure (aprox 15psi head pressure) when pumps are off.Water service on pump discharge. Is this a common trait for floating ball valves?
RE: Floating ball valves leaking at low pressure
I'm going to stick my neck out here and assume you mean the former. A floating ball valve seals by the ball shifting onto the downstream seat. The more dP, the harder the ball is pressed into the seat. When dP is very low, the ball is not held against the seat as hard (or at all) and the clearance between the ball and seat can allow leakage. If this is intolerable to your process I would replace the floating balls with a trunnion ball valve where the seats are held against the ball by springs.
David
Mike Halloran
Pembroke Pines, FL, USA
.. and to add to above answer, seat leakage of floating ball valves may start at low pressure, but might increase over time and after a time also include leakage at increasingly higher pressure.
A thorough analysis will include a large number of parameters, in fact all normal when selecting a valvetype, plus some 'not normal'.
Among others:
Are the valves built for and with a quality suitable for the service?
Expected lifetime?
Operation mode, cycles?
Fluid within given parameters for the valve?
Clean fluid or particles or unexpected particles and additions?
Seal quality, materials?
Maintenance done according to manufacturer specification?
Abrasive or sticking fluid particles when drying?
etc, etc,....
Solution may be given by answers to the analysis, but might also be to change to trunnion mounted ball valves, or to another type of valve construction entirely.
There is no place that I prefer plug valves.
I think that the most cost effective answer to a low dP leakage problem is a trunnion ball valve, but if the MAWP of the system is low enough you might be able to solve the problem with plastic-body ball valves.
David
in addition to gerhardl questions, I would ask: have the valves to be "piggable" (i.e. completely free passage when they are opened) or you can tolerate the presence of a stem and disc within the pipe?
Moreover, which is the maximum leak rate, more or less, you can allow?
Perhaps high performance (double-offset), rubber lined or triple-offset, metal seated butterfly valves may be a way (for sure the second ones will give better performance than gate valves)... but, on such a little size, you should also consider possibly bigger prices respect to ball valves and, of course, decide if that's worthwhile
See, for example: thread408-237869: Rubber-Lined Valves for Sea Water Service, thread408-126483: Discussion on triple offset valve, thread408-64692: butterfly valve and thread408-190488: 4 offset Butterfly Valves ( Quadruple Eccentric ) within this Forum.
(Maybe this is a little off-topic... but I think zdas04 already answered the original question).
Hope this helps, 'NGL
but, I guess that downstream seats damaged at your existing differential pressure(600 psi).
I strongly recommend to change a seat design in my experiences(reinforce a strength and dimensions)
Most any floating ball valve comes out of the box with preload/interference fit on the seat so that it seals at low pressures. Virgin TFE is famous for having low "memory" so once it's exposed to 600 psi shutoff for a while the downstream seat is permanenetly distorted. So, when you go back to low-pressure, the preload is gone and it weeps.
There are veritable multitudes of formulated TFE-based blends with minerals, glass fiber, carbon in many forms, eyes of newt, (whatever). All make the seat less prone to cold-flow. So it will continue to seal after the pressure is reduced.
Delrin, PEEK, and other polymers are also available, with much better success at high pressure swings.
Gate valves leak.
Plug valves are hard to turn, but they can be adjusted to restore shutoff if they do begin to leak.
Double-offset butterfly valves also have resilient seats made out of essentially the same stuff as ball valve seats and they are also process-energized, so some of the same limitations apply.
Triple-offset butterfly valves have a lot of machinery that lives in the flow stream when they are "open" so capacity is affected. And they reqiure you to lean on them mightily to get the vaunted "zero leakage" . This is called "torque-seated" in the literature. You CAN get tight shutoff, but you'll need a strong helper and a bunch of bananas.
