Code for direct gas fired makeup air unit
Is direct gas fired makeup air unit allowed in the indoor ceiling space for commercial kitchen application?
Where can I find the code regarding to this?
RE: Code for direct gas fired makeup air unit
Building Code
International Fuel Gas Code
NFPA 54 (National Fuel Gas Code)
Lemon,
if its 100% OA and not living quarters, you should be able to, but read your codes.  NFPA 54 section 10.  Make sure you bring in enough OA to dilute the combustion gases.
Thanks cdxx139 and PEDARRIN2. I found it.
