Miniature Scissor Lift
Dear all,
I need to design a miniature electric scissor lift. Generally, it must be no larger than about 30 mm X 20 mm and a extended height of 10 mm. Minimum height is of a high importance and must be equal or less than (if possible) 5 mm. This lift must fold. Therefore, a screw actuator is needed.
My question, is it possible to find a linear actuator miniature enough to fit into the mechanism. Moreover, how could I calculate the diameter of scissor arms that can support predetermined force (100 N) on the upper plate when the scissor lift is expanded.
Thank you in advance,
Shaban
Shaban
RE: Miniature Scissor Lift
Ed Danzer
www.danzcoinc.com
www.dehyds.com
EdDanzer, the change of piezoelectric materials as a response of the applied voltage is too small - of the order 10e-3 mm. As I told before, the change must be between 5 and 10 mm.
Thank you.
Plus needless to say if I could design such a thing I'd be off designing artificial hands and the like.
Cheers
Greg Locock
Exactly, that's all I need to know. Is there any miniature linear actuator that could fit in the aforementioned scissor mechanism and could provide such a force?
Cheers
Greg Locock
Cheers
Greg Locock
