Please Heeeeelp!
Please Heeeeelp!
I am writing a program for a resonator. The code seem to be wrong somewhere at the end of the program and I can't figure out how to correct it. Please, kindly help me. I have attached it so you can view and see where the problem is.
Sheeni.
Sheeni.
RE: Please Heeeeelp!
John D
Many thanks,
Ganiu.
I have tried what you asked me to do but it didn't work. The system displays "Mathcad Application has stopped working - close program" and then shuts down. What do you think is responsible for this? Do you think my program is not correct somewhere? I've tried to figure out where but couldn't. Please help me.
Secondly, P(0)f is not plotting. The program automatically closes when I try to plot it. Why do you think this is happening? It's saying "this value must be a matrix of scalar elements".
Thanks in advance,
Sheeni.
For your question about Q0, it will be easiest to work with the xmcd file. Please attach that to your next post.
Peter
Sheeni.
Take a look at the alternate graph and let me know if that is what you had in mind.
Regarding P0 and S21_0, 10log(P0) is equal to 20log(S21_0) due to the square term in the definition of P0.
Peter
Thanks.
I have attached a word document too maybe you'll understand better what I want to achieve. I have modelled a resonator used for broadband measurement. The fundamental frequency is 1.25 GHz and has other modes as shown in the file attached. What i want to do is to reproduce what is in the attachment in MathCAD using the equation S21 which I have developed. I think you'll understand better if you view the attached file. Thanks.
Thanks that does help. I can tell you the form that the solution must take at least. For each peak in the response, you need one 'zero' in the denominator. The way your current equation is written the location of the zero is determined by (f-f0). since f0 is a constant, the zero is always at the same frequency irregardless of the value of Q0.
I've attached a worksheet to demonstrate the form the equation must take. The caveat being that this is SOLELY to demonstrate the form of the equation - see the explanation in the xmcd file.
Peter
I have a lower version of mathcad so i can't view your document. Please can you save it with a lower version and resend it? thanks.
Peter
