how do I switch windows?
I am running an internal plug-in for AutoCAD 2000. When the application is finished, it activates a dialogue box or message box with an okay button. I would like to be able to switch to this dialogue box and close it by either clicking the ok button using vba code for AutoCAD 2000 or closing the window. I am trying to combine commands into a single toolbar button. This dialogue box appears at the completion of the second command in the program. I need to close this dialogue box so that I can return to the command prompt to execute my next command with the vba code. I cannot edit the plug-in because it is encrypted.
Kirk
Kirk
