Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...What a great service! This is the best site I've ever seen!!! It totally restores my faith in humanity when people take time out to help other people..."
Geography
trxt (Aerospace)
10 Sep 09 16:42
Hello Everyone,
I m looking for a kind of PET film or alternative material which is highly transparent but has nonreflective characteristic for clamshell/blister packaging. Blister package is shining under the spotlight of the shelf and the product inside the package can not seem properly. PET is my priority due to costs but i am open to every proposals.
Thank you for your helps..
Demon3 (Materials)
11 Sep 09 17:25
Your only chance is to put a texture on the surface of the blister film. Gloss comes from having a smooth, flat surface. If you can mold in a micro texture then you can reduce gloss but stay with the transparent PET. The material is not the problem, it's the surface. You'd have the same gloss problem with any plastic.
Chris DeArmitt
www.phantomplastics.com
Consulting to the plastics industry
trxt (Aerospace)
12 Sep 09 16:18
Hello Chris,
Thank you for your response. I agree with you. Gloss comes from the surface which is smooth like glass.
but if we make microtexture on mold , Probably trancparency will also be reduced. Right?
I will make microtexture on thermoform mold and i will evaluate the result.
Demon3 (Materials)
13 Sep 09 14:39
Yes, the texture will reduce transparency somewhat.
Chris DeArmitt
suselinux (Industrial)
3 Oct 09 0:57
I've worked with no glare Acrylic before, it's made for signage, its clear to see through but one surface has something similar to a very, very light sand blasting.  You could also try very weak chemical etching.
trxt (Aerospace)
3 Oct 09 17:14
Hello suselinux,
Thank you for your message. How about the transparency loss?
Transparency is very important for my product. It must be like glass.
I am curious about the acrylic sheet you suggested. Is there a web site refer to this pmma sheets?
patprimmer (Publican)
3 Oct 09 21:42
Any attempt to reduce glare must disrupt reflection from the surface. This means reducing the smoothness. This scatters light. This reduces transmission and clarity to some extent.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
trxt (Aerospace)
14 Oct 09 3:19
Pat,
there are some pvd optical anti-reflection coatings doesnt disrupt the transparency.
they apply on eyeglass and good results can be achieved.
But , i would rather to solve this through plastic operation.
14 Oct 09 6:47
I think you will find there is some compromise with anti glare vs sharpness and transmission even with eyeglasses and camera lenses, well at least there should be according to Isaac Newton.
Pat
for site rules
MacGyverS2000 (Electrical)
14 Oct 09 8:03
You can't get past basic physics (at least not without the budget of the Hadron Collider)... if you get rid of reflections, you're getting rid of transparency.
Dan - Owner
http://www.Hi-TecDesigns.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
