External Design Tables and copying assemblies
I have an external design table the performs calculations to size components for an assembly. It controls the assembly and the parts.
I want to make a copy of the assembly using "Pack N Go". When I do so the copied files still point to the old design table location. Is there a way to get the references to the external design table to update with the move of files?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
RE: External Design Tables and copying assemblies
If the calculation table is made externally as a separate Excell spread sheet, it will only point to the original model file(s) that the sheet is concerned with.
The Excel sheet will have to be copied and pointed to the new file(s). This because the property information for a given dimension in the Excel cell points to the cooresponding dimension in the SW model file that it started from. The model name does not change in the cell information when the copying occurs.
If the table was imbedded with the design table function in SolidWorks, you have better luck with copying process.
Christopher Zona - Product Designer
Loretto, Ontario
James Spisich
Design Engineer, CSWP
The design table was developed to run the assembly and all the parts. That is the problem.
TOP
CSWP, BSSE
James Spisich
TOP
CSWP, BSSE
