Back ground color in assembly
Hi, I try to change the color of me assemly back ground in option tab but it's does't work when I do OK. No color change, nothing happend !!!! Why !!!
Help me !
THX
RE: Back ground color in assembly
I think you have still gradient active, so reset this to 'SE Default'
(Format - View - Background). Then the change done by options Colour
should work.
To set it permanently to 'SE-Default' you have to change the appropriate
template. OTH the background color is stored along with the file. So
when you open an 'old' file the background color might be different
dy
