Recent condenser type in vacuum tower O/H system
Re the vacuum tower having O/H condenser designed and installed by fixed type cooling water cooler to prevent leakage from atmosphere to system, several questions are raised as below.
1)Fixed type O/H condenser is very difficult to clean
  outside tube during T/A period. So, we are considering
  general type of exchangers(such as AES type) to make
  clean easy. Please comment.
2)Is there any recent up-to-date exchanger to have good
  vacuum during entire operating period ?
3)Other comments to be awared to keep good vacuum always.
  end.
RE: Recent condenser type in vacuum tower O/H system
AES is not good option for high vacuum applications. Pressure drop is unacceptable. Tema X shell (crossflow) is considered as standard overhead condenser type in vacuum towers.
In recent projects I have seen AXU/AXS and AEU/AES (at higher pressures).
In all cases these exchanges were supplied by the ejector vendor, and their bundle layout/arrangement were different from typical exchanger, presumably to keep the pressure drop down.
