Maximum recorded wet bulb temperature
What is the maximum recorded wet bulb temperature ? What happens if the wet bulb temperature exceeds 36.9 deg C (98.4 deg F) ?
HVAC68
RE: Maximum recorded wet bulb temperature
However, at 36.9C a black hole would form at the center of your sling pyschrometer.
The way we build has a far greater impact on our comfort, energy consumption and IAQ, than any HVAC system we install
Maximum wet bulb temperature shall be at the most few degrees lesser than the maximum dry bulb temperature.
HVAC68
HVAC68
Good on ya,
Goober Dave
