Runway beam Design code
Hi All,
we are designing a runway beam ,i would appreciate if any one could let me know any relevant american codes that i can use for designing the runway beam.
we have been using eurocodes in the past,but the beam is failing under the code.
Badri07.
Badri07.
RE: Runway beam Design code
Thank you for your mail,infact we are just checking the beam,
we did check for the BS2853,it failed for the said standard as well.
Dik
Be sure you are using the proper loading conditions for single & multiple cranes, impact loads, traction lods, and side thrust loads.
