Dosing control help.
I am trying to deliver a pressure profiled dose of water.
About 3 oz or 90ml per minute.
I have tried a very small expensive gear pump and I'm entirely dissatisfied with the static leakage thru it.
I have about 30 psi of feedwater to the system and I want to be able to provide about 1.5oz over about 1/2 a minute with a pressure of anywhere between zero and 130psi.
With my current pump/system I am faced with 30psi to 130psi and the difference in flow is only about 1:2 over the leak thru verses 130psi.
Any suggestions of systems or techniques I should be looking at?  I am not having much luck with search terms either.
I can actually have a recharge period of a few seconds per dose if that broadens the field of choices.  Syringe/piston style??
Keith Cress
RE: Dosing control help.
Hi Keith,
                 I'm a little confused by your description.
Why not use a diaphragm type metering pump c/w back-pressure valve?
If you pick one that will deliver say 200# and have a 50# back-pressure valve the line pressure would have minimal effect on the flow.
You can operate the metering pump on 4-20 mA or a pulse from a PLC
e.g. 0.1 oz per pulse at 15 pulses per minute. If you need a smoother flow use smaller increments at higher frequency.
Brooks make small mass flow controllers that might work, I have only used the gas type but I'm fairly certain they have a liquid one also.
Roy
Hi Roy,
I was hoping you would come by.
That sounds excellent.  Especially with the back pressure valve.
So let me see if I get it. I have to run a regulator in front of the diaphragm pump to limit incoming pressure to, say, 30psi.
Then the pump.
Then the back pressure valve(BPV) with, say, a 50psi spring/ball setup.
So nothing flows until the 50psi is reached.
I can then control the pressure after the BPV because there will be a restriction at the delivery point.  This means I could actually have 2,3 5, 20psi after the BPV as controlled by the flow and the exit restriction?
See any difficulties with 200F and this scheme?
Keith Cress
I have used about 5 years back a coriolis based mass flow controller brand 'bronkhorst' it was working fine.
last year I bought some dosing pumps, giving a certain quantity per stroke, these where expansive and bad functioning.
www.bronkhorst.com
Keith,
       Yes,. I would drop the pressure right down or use a small tank.
Check out accessories under the following link, it gives a good description of the back-ressure valve.
AntronTRN is right metering pumps can be a bit of a pain, but they are a way cheaper than a regular meter, control valve setup. We use them quite often.
I will look into other options as well.
I see another thread on metering pumps, check that as well
http://www.lmipumps.com/corp/details/0,,CLI1_DIV12_ETI3738,00.html
Roy
Keith,
      Check out the coreolis mass flow controllers from Brooks, one of those might fill the bill. I'm pretty sure I have seen a thermal mass for liquid also.
If you do a web search under mass flow controllers you should find a bunch of other brands.
The nice thing about these they have a meter, control valve anf PID function all in one tiny package.
As I said I have only used them on gas, so if you go that way make sure you hve a filter upstream.
http://www.brooksinstrument.com/category1.asp
Roy
Thanks Roy, AntonTRN.
Let me digest this.
BTW The last mass flow controller I purchased was tiny (1/4 tubing) and cost $5,100!!
Keith Cress
Keith,
      About Canadian $1700 here for a Cole Palmer suitable for water.
       If you want to send me a few more details on what you are trying to do I may be able to suggest something better.  rmatson at noram-eng dot com
Roy
