L Bracket joining 2 carbon composite panels
Just wanted to check what are the views of you guys who has experience of two composite panels in pressure deck area with L bracket which can be metallic or of composite.I wanted to check which will be more useful or valuable to the design and construction ?
I have attached picture for same.
Please do let me know your opinion.
RE: L Bracket joining 2 carbon composite panels
Please do let me know your views.
a formed angle looks better at accomodating the rotation dispalcement expected if both panels are pressure skins. if the dark blue is the only pressure skin then there would tend to be more of a tension load on the angle (as the dark blue would displace away from the light blue) ... offset so a little bending introduced.
but (of course) the angles main job is to transfer shear from one panel to the other.
Please do let me know your thoughts.
Aluminium would be easier and cheaper to form, but would have to be isolated from the carbon.
http://www.mathiverse.com/forum
* plus fasteners at metallic frames and fittings
**machined or formed, each has advantages
Regards, Wil Taylor
I am doing analysis for L Bracket connected to pressure deck at bottom(blue color) and T Section adjacent to it on pressure deck as L Bracket connected to skin on sideward.
Any idea of approach for this analysis I should focus on.
Please advise.Picture is in the first posting attached.
Body
Diagram
ie, a cross-section picture of the part with all loads for a given load case shown on it.
not a dump of numbers from a FEM
