DC Motor/End of Travel
I have an application where a DC motor drives a leadscrew. At the end of travel, there is no limit switch. The current design uses a poly-switch to determine the end of travel has been reached. I'd like to change this to something a bit more fast acting. My first thought is to use a current sensing ckt. (cheap op amp and a few resistors). Any other ideas? Thanks.
RE: DC Motor/End of Travel
<nbucska@pcperipherals.com>
