H2S Scavengers
H2S Scavengers
H2S Scavengers
I am looking for the basic chemistry of common liquid H2S scavengers. Can anyone help by providing the names of these chemicals? Thank you.
RE: H2S Scavengers
ammonium hydroxide
caustic
Any basic compound
Destination of neutralized stream plays key role
RE: H2S Scavengers
Many H2S scanvergers will be amines at least those used upstream in O&G,
Best regards
Morten
RE: H2S Scavengers
You might get different answers if you told us the scale of the project.   How many SCFM of gas are you dealing with?  What are the H2S concentrations coming in?  Going out?
Oil field?  Labratory?  Chemical Plant?
StoneCold
RE: H2S Scavengers
You can also look at formaldehyde, or try morphysorb, or even any kind of amine will be a scavenger, DGA, MDEA, MEA.  Even sulfolane will likely work.  Let's face it, water will also work if you have enough of it.
RE: H2S Scavengers
Thank you for all the responses. I have been able to compile a list of fluids.
