How do I change the Units in 160 drawings?
I have a group of 160 drawings that have the Units set to Engineering and I need to change them all to Decimal. How can I do this in one step outside of AutoCad?
I'm using LT 2009.
Frank
RE: How do I change the Units in 160 drawings?
filedia
0
open
[NAME OF FILE]
-units
n
save
close
Then repeat for each file name. It's crude but can work without having to learn LISP.
I don't know what the numbers are for. Do they represent the listed items in the Units box? It shows Architecture as first, Decimal is second, etc. Is this what the 2 means? I usually just select Decimal then OK the box. What are the other numbers for, and the letter n?
Thanks for your help.
Frank
I suggest you work on one file manually by typing the commands and writing down exactly what you type for the commands and responses.
Good luck!
Frank
add all your 160 dwg files that you need to perform the -units operation on, add the script file, let it run! i suggest doing it over lunch and keep your monitor on for everyone else to watch in amazement :)
Create a new toolbar button.
In the Button Properties dialog box, assign the following macro to the new button:
^C^C-units 2 2 1 2 0 n
Mauro - Tecnocentro eng srl
www.tecnocentro.it
