Re: Repair Works to Cracked Wall
I'm looking at a cracked wall that has experienced some differential lateral movement. I'm pretty sure that the crack is due to the wall performing a small retaining role (about 300mm a single skin) which has been exasperated by car being parked nearby.(The possibility that someone has crashed into it would also be plausible)
My initial thoughts are to remove 2 blockwork units either side of the crack and course in an engaged pier but haven't a great deal is experience in this sort of stuff so was wanting to sound out some other options.
RE: Re: Repair Works to Cracked Wall
BA
Scott
www.dbssinc.com
It looks like a thin wall that was improperly used as a retaining wall and/or may have heaved due to the climate.
Dick
